associativity in nx drafting
i want to associate "note" and "label" to dimension in nx drafting. but the procedure for this provided in NX is too repetitive.
can anyone have the codes for this so that i can run the dll file and keep the note as desired place......??
RE: associativity in nx drafting
Can you describe the repetitive process ?
what is happening and what does not happen ?
this can probably be done in different ways, and maybe different methods depending on the NX version.
What NX version ?
Tomas
This is NX 8.5. Here we select the object (note or label) and by double clicking, we can go to origin tool option and there we can provide the x and y co-ordinate values w.r.t the desired dim. so that it will be associated with the dim at a particular location.
