Grinding composite plate
Dear experts,
We are looking for a supplier that could grind a composite plate (epoxy resin matrix reinforced with glass roving fabric). Plates would be about 2200x1300mm.
Any hints?
Thank you in advance
Any hints?
RE: Grinding composite plate
Remove the glass.
Mike Halloran
Pembroke Pines, FL, USA
Not sure I fully understant Mike's suggestion. Do you have some place I can get more info on the process?
Plates are already made. I do know that is feasible to grinder them, as we used to do it in-house. But we struggle to find someone outside
Over the years I have been bitten by changing the dialectic of the material, incompatible residues left on the surfaces, moisture up take in the material etc. etc. You need to understand what the intended end use is and what both the expressed and inferred specifications are..
Good luck -- the devil is often in the details
