Ribbed Structural Nails v.s. Glue coated Nails
I was just wondering what the difference is between the two. Are there significant withdrawal loads each can withstand? I have a set of plans which calls out that "ribbed structural nails, not glue coated shall be used." is there a standard or code that reinforces this statement? I also want to know if a ribbed structural nail is glue coated wouldn't that create a stronger connection?
RE: Ribbed Structural Nails v.s. Glue coated Nails
Wood As An Engineering Material - Chapter 8 - Fastenings
www.SlideRuleEra.net
www.VacuumTubeEra.net
Bostitch claims normal ring shanked nails have ~ 10% greater than smooth shanked nails.
Table 3, page 13 (21) here -
http://www.bostitch.com/xhtml/literature/GA1381_Fa...
