High hardness values fillet weld
I have the following material per Shell's specification (F552) with the below composition:
- 0.13 %C
- 0.51 %Mn
- 2.39 %Cr
- 0.99 %Mo
- 0.006 %V
- 0.11 %Ni
- 0.08 %Cu
- 0.35 %Si
- 0.51% Mn
- 0.0004 %B
We are looking to weld it to S355, fillet weld, although the fabricator is having hardness problems. These are the parameters:
- Preheat 200C
- Position 2F
- Fillet metal GTAW ER70S-3
- Amps 179A
- Volts 11.2V
- Speed 13cm/min
- HI 9.3kJ/cm
- Post heating 250C during 30min + cooling under cover sheet
- No PWHT
Hardness values are 410Hv.
Any ideas to reduce these values? Thank you.
- 0.13 %C
- 0.51 %Mn
- 2.39 %Cr
- 0.99 %Mo
- 0.006 %V
- 0.11 %Ni
- 0.08 %Cu
- 0.35 %Si
- 0.51% Mn
- 0.0004 %B
- Preheat 200C
- Position 2F
- Amps 179A
- Volts 11.2V
- Speed 13cm/min
- HI 9.3kJ/cm
- No PWHT
RE: High hardness values fillet weld
