Problem with view dependant edit, to show desired hidden lines
when using the approach http://www.eng-tips.com/viewthread.cfm?qid=340457 to show desired hidden lines we have hit a problem.
When turning the hidden line font back to invisible, all lines disappear including the edited ones. Is there anyone else who has had this problem and knows a fix?
Is there any setting we might have changed to make it behave this way?
This worked fine for until a certain date.
We are running NX 8.5
Any help on this will be greatly appreciated.
Best regards
Per Åge
RE: Problem with view dependant edit, to show desired hidden lines
Have a look here:
thread561-395730: Hidden lines NX10
I'd guess that you are using the "exact" view type as opposed to the "pre-NX 8.5 exact" view type. The thread above may give you a work-around.
www.nxjournaling.com
Thanks cowski,
the effected views are "exact"
Best regards
Per Åge
