Which Surface definition is the most precise and Exact in SolidWorks ?
Hi All
I wanted to know if the NURBS surface definition the most exact surface definition in Solidworks ? I have a problem , that when I define even a hollow cylinder , and export it as .STEP , to use in a FEM software , I see the surface has many facets to edit, before using, otherwise I will have contact definition problems , any many more, shall someone advise me how to define such a geometry, and definitely much more complex ones , in the most precise method , with the lowest tolerance possible ?
Thank you so much
Thank you so much
RE: Which Surface definition is the most precise and Exact in SolidWorks ?
Rob
Rob Stupplebeen
OptimalDevice.com/blog
Rob's LinkedIn
