Why replace carbon steel bolts with Stainless Steel
Auditor insisting all carbon steel bolts be replaced with stainless on SS code vessels, but I have not got a definitive answer why?
Talking thousands of carbon bolts ($$$) that have been in service with no problem for years. I must be missing something
Any dialogue would be appreciated.
RE: Why replace carbon steel bolts with Stainless Steel
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
If he can't cite a specific violation or non-compliance just tell him to go away.
Also, it's unusual for an audit process to direct a "corrective action". Typically the audit identifies "findings", and the auditee responds with the corrective action, which may be "it's fine as it it."
There are a few reasons to consider SS fasteners:
1) External corrosion conditions, where you're worried about the CS fasteners being eaten either directly or as a result of galvanic corrosion.
2) Concerns about contamination of the stainless steel surface by contact with the carbon steel, leading to premature corrosion of the stainless steel. This is usually a dumb one- not really a concern.
3) Very high temperature operation, where the temperature limits of the CS fasteners are exceeded.
4) Surface cleanliness/cleanability for high purity applications
No inspector should be telling you what needs to be used without a reference.
the max plant temp is 450 F but seldom runs at that high of temp.
