Recommendations for a good vibration measuring instrument.
I was looking to buy a instrument to measure vibrations (i.e. amplitude, velocity, and acceleration). I have found some fairly cheap stuff (which is always good
), but I wonder about its quality and I also am concerned that most of them I have been able to find cannot measure frequencies below 10 Hz. Therefore I am looking for recommendations. A recommendation for ground motion measurement is also welcome.
RE: Recommendations for a good vibration measuring instrument.
If you need higher frequency response, an accelerometer is likely a better option. They are cheap, but require separate dataloggers that can be pricey and difficult to program.
Mike Lambert
You might try the Modal Shop in Cincinnati. They also rent equipment.
Link
DB
