Rankine vs Coulomb Failure envelope
As for the Rankine method (where the active failure plane behind the wall = 45+phi/2), can someone please explain to me (or at least point me in the right direction) how you would derive the failure plane angle for the Coulomb method?
RE: Rankine vs Coulomb Failure envelope
You should be able to find one on internet. It is a monster formula.
If you wanted to "derive" it then have fun with math.
forfrom the vertical or horizontal.www.PeirceEngineering.com
