DWG file not importing to drawing
Hi i have a drawing template created in catia and saved as .dwg. but when i tried to import it to nx, it is imported to 3D.
Does anybody know what i am doind wrong. is there any way to importing it to drawing sheet. thanks in advance
RE: DWG file not importing to drawing
Sounds like there might have been an issue when the Catia model was converted to a .dwg file. Did you try rounding-tripping the .dwg file back into Catia to see what was actually exported and how it gets returned?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for the reply.
Yes, there is no issue with catia. it opened in drawing in catia. issue is only when i importing to NX.
What version of NX? In recent versions there is a dwg/dxf import wizard; specify the dwg file to import and press the "preview" button. If the geometry that you want shows up in the "model" tab, choose the "send model data to: drawing sheet" option. This will create a new drawing sheet in the file and import the geometry directly to it.
www.nxjournaling.com
In Input and Output tab, should i select Import to Work part or New part?
If i select work part, Highlighted option is not available in options tab
Thanks for the link cowski, It workedthanks
