Trumpf Laser, recovery after a E-Stop
Do someone know about how to reset the automation after the safety perimeter has been triggered while in load/unload cycle ?
The machine is a TL2030, year 2008
Trumpf service's say we need there technicien to do the so called ''Recovery''.
thank you
thank you
RE: Trumpf Laser, recovery after a E-Stop
When that occurs, the machine lost its position.
It ask for the home position, but do not want to move until everything is at home position.
You see the trouble ...
Trumpf service tech have a little ack to make it easy, instead of cheating many sensors to tell the machine it is where it want to be.
I was hoping someone know this trick
Try to move the frame that is out of position with the switch elements
Try doing a reboot on the machine.
that will usually let it find itself
