internal pressure for structural design
hi,
i am designing a plated structure where client has specified to use
design internal pressure as 660mmWc at 67% yield strength.
as i am designing the Structure to LRFD - IS it Required to Increase the internal Pressure to 100% yield strength
i.e. 660/0.67 = 985 mm wc for Design of Structural Members?
thanks
thanks
RE: internal pressure for structural design
660mm = 25.98" mercury or 352" H2O = 29.36' H2O = 1832 psf. Wow!
Edit: This is nonsense. See following posts. Please ignore this post!
BA
It didn't indicate this was a building of any kind.
BA
Client maybe using the old ASD-89 0.66FY bending for beam, which should have been 0.75FY bending for plate.
If the standard code check for ring tension would be 0.9Fy, I'd set the load factor such that (0.9Fy)/Factor=(2/3)*Fy. So your load factor would be 1.35.
