Help with greyed out commands
RE: Help with greyed out commands
Make sure you are in the Modeling Module and not Gateway.
Also make sure you are not in an active sketch.
I had that problem too, a few weeks ago. After logging off (for the day) and then back on (the next day) the commands were no longer greyed out.
That toolbar, is it homemade ?
Chances are that you have added commands( icons) to the toolbar which only are active when a sketch is active and vice versa. ( the toolbar might not be visible when a sketch is active etc. )
Tomas
Actually those commands look like they might be Sketch commands. Is it possible that when you created your toolbar that you included sketch commands but now you're not in a sketch so they are not available?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you for the responses. It is a 'homemade' toolbar, and I am in
modelling.
I went into customize again and deleted them. They were inserted from
the 'All commands'category. I then input them from the 'menu' category,
and they are operating normally. Not quite sure why that worked?
Best regards
