LOAD OPTIONS like PRO_LIBRARY_DIR with Wildfire or Creo
Without any management mode it's possible to optimize search standard component by using variable PRO_LIBRARY_DIR with Wildfire or Creo.
Is there an equivalent with NX8.5 ?
TIA
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: LOAD OPTIONS like PRO_LIBRARY_DIR with Wildfire or Creo
How do we know what and how "Pro_Library_dir" is ?
I have no clue.
Tomas
I hoped to find a former user of Creo in our forum.
Find attached a PDF file that explain the process but it is in french
Didier Psaltopoulos
The load options file can be set much like the pro_search.pro file.
What are you trying to do in NX that can be done in Creo? There is very little that cannot be programmed into NX to do things easier.
Ben Loosli
I've been looking for a way to set up a search path for my library of parts that will work with "Load Options" set to "From Folder"
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
