T-beam Design - Slab reinforcements.
I need some help guys, I'm a bit rusty with my concrete design. I am to analyze an existing concrete building with T-beam construction. I am wondering if you guys consider the slab reinforcement as part of your As and/or As'. The building is in a high seismic zone area. I am aware of the ACI strong-column-weak-beam requirement that you need to include the contributions of the slab reinforcements in your beam flexural strengths. Is it just for that requirement or can you use that it in general? Hope you guys can help. TIA.
RE: T-beam Design - Slab reinforcements.
Only reinforcement within the beam web width can be included in the shear design.
1) Can use As, probably wouldn't use for As' unless well restrained from buckling.
2) Rebar lateral offset from beam web extends bar extension lengths.
3) Watch your splices in the slab rebar.
4) Most of slab rebar won't be useful for transferring moments into columns.
Exactly.
