Shear plane reinforcing
I have inherited a project that has issues. There are embed plates supporting beams that do not meet ACI Apendix D requirements. An idea that has been presented that involves crossing the possible shear failure planes with new rebar epoxied into the wall and welded to a plate to develop the rebar strength on either side of the possible shear planes.
I have not used this approach before. ACI gives examples of providing reinforcing when it is parallel to the force and within a distance from the anchor which I have used many times before. In this case the new reinforcing for the existing plate and studs will be perpendicular to the shear force. My concern is the theoretical shear planes may not be the actual shear plane and the new reinforcing I am showing may not be located where it will be required, and will therefore not intersect the plane as needed to develop the yield strength of the bars on either side of the plane.
The idea is to keep the shear plane intact thru shear friction using new epoxied rebar. I have attached a sketch of the concept. Anyone done this before?
RE: Shear plane reinforcing
