Difference between pneumatic and hydraulic cylinders
What is the fundamental difference between the construction of pneumatic and hydraulic cylinders? I sense that pneumatic systems respond quickly and hydraulic ones are capable of much greater thrust over a generally-longer actuating time. But pneumatic cylinders are very inexpensive and hydraulic ones are not. I have an positioning application requiring the precision of hydraulics; that is, a system where the fluid cannot be compressed, but a budget that favors a pneumatic cylinder. Can a pneumatic cylinder be used with hydraulic fluid (oil, brake fluid, water... whatever) as long as the pressure behind the fluid is not great? 50psi would do the job just fine; it's four inches of piston travel over the period of a half an hour or so, and I was going to pressurize one side of a cylinder and let the fluid from the other side leak out through a needle valve. Any tips would be most welcome.
RE: Difference between pneumatic and hydraulic cylinders
Ted
That's kinda what I figured. My main worry is how the construction might differ that would make using a pneumatic cylinder in a hydraulic application a bad idea because of what these cylinders are like inside. My pressure would be under 100 psi, but would hydraulic fluid be bad news for whatever O-ring or other seal might be used in a pneumatic cylinder? Also, are pneumatic cylinders made to as rigid specifications? I mean, if an air cylinder leaks a bit, no big deal usually. But if hydraulic fluid seeps out around the seals, that would not be good.
Ted
For us the big deal was seal compatibility. For the next project it might have been pressure and so forth. If I was starting from scratch, I'd pony up the money for hydraulic cylinders out of the box.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
There will be some oil carryover on the cylinder rod as most rod seals do not wipe the rod powder-dry. A film of oil lubricates the rod and seal.
Ted
Ted
