Parts List Strikethrough text and New Part order
I have a drafting of a assembly with several parts. The part list of the items are created with settings->
Grow Direction-Up
Automatic Update-Selected
Sort on Update-Selected
Lock Parts List setup
Create New Rows as Locked-Selected
Allow Manual Rows-Selected
Locked Deleted Rows- Strikethrough-Selected
Also i use this part list to auto-number the assembly.
When i replace a component of the assembly , the new component comes with same part number as the replaced part and the part disappear from the part list , whereas what i require is the old part to be striken-out with qty 0 and the new part to be added at the end of the part list.
I refereed old posts-
http://www.eng-tips.com/viewthread.cfm?qid=233949
http://www.eng-tips.com/viewthread.cfm?qid=263124
but still cannot make it work.
Vipin
RE: Parts List Strikethrough text and New Part order
Hello Vipin,
Right-click and select to lock the parts list row before you replace the component and then "delete" the parts list row. You will get a strike-through cancelled item.
~Felicia H.
NX 9.0.2.5
"Design all things as simple as possible but not simpler."
Hi Felicia ,
Thanks for your reply.
I have resolved the issue in a similar manner u mentioned.
Only difference is i am making a temporary copy of the part inside assembly before locking the row and replacing the part.
Then replacing one copy of the old part with new part (replace only 1 occurrence) and deleting the other copy of the old part.
The strikethrough will appear only when the part is deleted, not for replace (someone from Siemens told me so).
Vipin
