Modelling a protective foam around a skull
Dear all,
I have an orphan mesh of a human skull in Abaqus. What I would like to do is to create a foam and wrap it around the skull (around the forehead area). So how do I go about doing this in Abaqus? The skull has irregular geometry. Your help is truly appreciated. Thanks.
RE: Modelling a protective foam around a skull
Hi IceBreakerSours, thank for your reply. I know about create the shell and solid from the mesh. I am interested in solid elements. But the problem is, if I would like to vary the thickness of the foam, would it be problematic? What if I wanted to play around with different designs as well, i.e. honeycomb foam. Would I be able to do this with that technique?
I always suggest creating complex geometries in your CAD program. A variable offset surface or offset honeycomb may even require a powerful CAD package.
I hope this helps.
Rob
Also, I noticed that you posted in the biomechanics forum. Generally this is frowned upon. I personally don't care but do like to see cross-reference links.
http://www.eng-tips.com/viewthread.cfm?qid=399602
Rob Stupplebeen
OptimalDevice.com/blog
Rob's LinkedIn
OK thanks. I'll try to figure out how to do this in CAD.
Sorry for the double posts.
