Catia v5 r2015
Catia v5 r2015
I have tried the new release of v5, and I become quite happy with it. I have found for example in sketch mode, an auto dimension option, and now variable radius Cordal radius is in the same command.
I would like to see a text option for part design. When it will be applied?
RE: Catia v5 r2015
Are you referring to the ability to write 3D text on a part? This is a major oversight in V5. There is a text tool in V6, but not in V5. The answer from Dassault has always been "use Type3". There are several workarounds out there. You could write text in a drawing, export to dxf, then import and copy/paste into a sketch, but the resulting text will be made up of only line segments - not curves. I helped develop another solution - Text Sketcher. It's a plug-in for V5 that allows you to write G1 continuous text in a sketch.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
RE: Catia v5 r2015
RE: Catia v5 r2015
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
RE: Catia v5 r2015
RE: Catia v5 r2015
