Beams Parallel to Precast Hollowcore Planks
How do you feel about steel beams "up in construction" running parallel to precast planks. With precast on both sides.
A few concerns:
1.) Construction - how will they fit the precast in between the beams with beams on all four sides?
2.) Deflection - I would support the precast with an angle in the web of the steel beam but I suppose this part of the floor will deflect differently than the rest.
Has anyone done this?
The issue at hand is a large notch in the exterior wall, which is framed with steel beams.
A few concerns:
RE: Beams Parallel to Precast Hollowcore Planks
2) Camber in the plank can make this problematic. Some dry pack grout should get the job done though.
EIT
www.HowToEngineer.com
