Identification of a part connected between the wheel and axle of a trailer
Can anybody tell me the name of the part labelled(???) and its function?? Please find attached a picture.
RE: Identification of a part connected between the wheel and axle of a trailer
Cheers
Greg Locock
I too have never seen anything quite like the device in the picture.
It appears that the axle is rigidly bolted to the frame through the plates shown.
A serious vehicle manufacturer would interpose some kind of spring or bumper in order to limit the forces applied to the frame at any speed; I infer that the assembly was put together by an amateur, or possibly an agricultural manufacturer, where the design speed is assumed essentially zero.
Mike Halloran
Pembroke Pines, FL, USA
The shaft operates a cam, which then pushes the brake shoes apart.
It used to be a quite "common" solution for airpressure operated truck brake systems many years ago, not sure what the current state of the affairs is in this respect.
In all likelyhood, it will look something similar to this inside the brake drum.
for agricultural trailers, you also find complete mechanical solutions, which use the inertia of the trailer, pushing against the braking tractor, to generate a braking force at the trailer - see below.
other agricultural solutions:
