Is there a trick to SAVE AS part B to a new revision of an existing part A in NX8.5 and TeamCenter8
Hi
In my company we work with nx8.5 under teamcenter 8.
I have 2 parts part A and part B
(the content of the parts are adaquate to the operation that I want to do)
I want to save part B as a new revision of part A.
Is anyone have a trick of how to do this.
Greetings and thanks
RE: Is there a trick to SAVE AS part B to a new revision of an existing part A in NX8.5 and TeamCenter8
Revise your part A , tell the system to discard the Dataset (to prevent it from being used in an assembly).
in TC save as your part B to the Part A rev (type in the part A ID). Most probably the system will tell you it is not possible to create the new dataset in Part A rev but it will create the dataset.
Search for the new dataset name and paste it in new rev part A.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Hi nutace and thank you for your help.
i will try it in next week because I am out of work now.
is "Revise your part A" I do it in nx or in tc and if in nx
How I "tell the system to discard the Dataset"
That is not possible in NX...You need to revise and do the save-as in TC
NX8.5.3 / TC9.1.2
HP Zbook15
THANK YOU.
You can use Named Reference swap from Part B after doing save as on part A to new rev.
Could you rename the revision A to a different revision. Open the renamed Revision "A" in NX and do a saveas to the ""A" Revision.
