Assign space bar as enter by sendKeys in vba script
I am using both AutoCAD and CATIA. I am trying to work the same way in CATIA as AutoCAD by giving commands through key board instead of using mouse.
I have customized the commands by user alias. My problem is when I give command in AutoCAD, after enter the command, I pressed the space bar for enter.
So, in AutoCAD command line, if we type the space bar, it will be treated as enter. But, when we come out from the command line for typing text, it will consider space bar for providing space.
I am expecting this property in Catia also that when I enter the space bar in command line, it should be treated as enter.
Please suggest any idea to assign space bar as enter.
From the internet, I came to know that, it is possible by sendkeys option in VBA scripting.
I tried the below script. But, it shows ‘VBScript compilation error’.
Kindly have a look and correct me the mistake.
SubCATMain()
CATIA.RefreshDisplay = True
SendKeys "{SPACE}", True ‘ENTER
End Sub
Suresh
SubCATMain()
End Sub
Suresh
RE: Assign space bar as enter by sendKeys in vba script
If you really still wanna do this I hope somebody here knows how to help you though.
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
