Pass login credentials to TCServer for running NXManager (external) programs
I need to run an NX-Manager External (.exe) application which needs to be run in TC-shell.
I want to know how to invoke the TC server prior to ruuning my application and provide login credentials -u=XXXX -p=XXXX format (Can someone tell me how to do this?)
so that afterwards i can run my application as
test.exe =pim-yes @DB/ABC/1.
I have set all environment variables TC/NX correctly in TC shell as per
http://www.eng-tips.com/viewthread.cfm?qid=348056
and is able to launch UGRAF.exe -u=XXXX -p=XXXX.
Vipin
Vipin
