Why are angular constraints so unreliable? NX9
I've suffered with them in Mating and Sketches. So often I've got an angular constraint set up and when I change other constraints in model the angular one flips to the opposite side of the plane or axis it was based on.
It spins the whole part or model around. I don't really get why... Am I missing some modeling 101 knowledge!?
I've had it with fixing this kind of stuff!!
TIA
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
RE: Why are angular constraints so unreliable? NX9
There are two different Angular constraint types, '3D Angle' and 'Orient Angle', If you're simply looking to set the angle between two Components and leave it there, then '3D Angle' should work OK. However, if you're wishing to frequently edit the value of the angular constraint using an expression then I would use the second type, 'Orient Angle' as it should prove to be more reliable.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I have had similar issues in Sketching for sure.
If you can provide an example of the where you've had problems with Angle constraints in a sketch, please at least post an image of the sketch if not the actual part file.
The same goes for any Assembly constraint cases.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John.
Can you send me an email address? I will send you a simple video of a sketch that I have issues with NX9+, my work firewall prevents me from posting it here.
Brandon
We are not allowed to post email addresses on Eng-Tips.
That being said, look at my user name, add a couple of periods where you think they should go and then add the siemens extension.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
