View Orientation Fit NX Journal for Assemblies
I am new to NX 7.5 and I am writing a Journal to simply fit the part within the view and then set the view to isometric, and save. My only difficulty is applying this to a large assembly that has 100+ Components and sub Assemblies. Currently I have the view orient code below. How do I apply this to multiple parts/assemblies?
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
workPart.ModelingViews.WorkView.Fit()
workPart.ModelingViews.WorkView.Orient(View.Canned.Isometric, View.ScaleAdjustment.Fit)
Dim partSaveStatus1 As PartSaveStatus
partSaveStatus1 = workPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
partSaveStatus1.Dispose()
End Sub
End Module
RE: View Orientation Fit NX Journal for Assemblies
Probably the assembly you're dealing with is the Display Part. So, modify your code to use displaypart rather than workPart.
That does help. I can open each component manually and run the code to do the view orient, but is there a way to search for children (components) and open each 1 x 1 and orient the views and save?
I've tried some variations with the lw Open command with no luck.
Update:
I've compiled code that works for the top assembly and the 1st level parts.
Is there anyway to modify this to work on subassemblies as well?
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.IO
Imports NXOpenUI
Imports System.Windows.Forms
Module NXJournal
Public theSession As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = theSession.ListingWindow
Sub Main()
Dim dispPart As Part = theSession.Parts.Display
'lw.Open
Try
Dim c As ComponentAssembly = dispPart.ComponentAssembly
'to process the work part rather than the display part,
' comment the previous line and uncomment the following line
'Dim c As ComponentAssembly = workPart.ComponentAssembly
if not IsNothing(c.RootComponent) then
'*** insert code to process 'root component' (assembly file)
'lw.WriteLine("Assembly: " & c.RootComponent.DisplayName)
'lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name)
'*** end of code to process root component
'lw.WriteLine("")
'lw.WriteLine("comps")
'lw.WriteLine("")
dim comps() as component = c.RootComponent.getchildren()
Dim part2 As Part = CType(theSession.Parts.FindObject(c.RootComponent.DisplayName), Part)
for i as integer = 0 to ( comps.length - 1 )
'lw.writeline( comps(i).name )
Dim component1 As Assemblies.Component = comps(i)
Dim components1(0) As Assemblies.Component
components1(0) = component1
Dim errorList1 As ErrorList
errorList1 = component1.DisplayComponentsExact(components1)
errorList1.Clear()
Dim part1 As Part = CType(theSession.Parts.FindObject(comps(i).displayname), Part)
part1.Preferences.Modeling.CutViewUpdateDelayed = True
Dim partLoadStatus1 As PartLoadStatus
Dim status1 As PartCollection.SdpsStatus
status1 = theSession.Parts.SetDisplay(part1, True, False, partLoadStatus1)
workPart = theSession.Parts.Work
dispPart = theSession.Parts.Display
partLoadStatus1.Dispose()
'Dim part2 As Part = CType(theSession.Parts.FindObject(c.RootComponent.DisplayName), Part)
workPart.Preferences.Modeling.CutViewUpdateDelayed = True
Dim partLoadStatus2 As PartLoadStatus
Dim status2 As PartCollection.SdpsStatus
dispPart.ModelingViews.WorkView.Fit()
dispPart.ModelingViews.WorkView.Orient(NXOpen.View.Canned.Isometric, NXOpen.View.ScaleAdjustment.Fit)
dispPart.ModelingViews.WorkView.RenderingStyle = NXOpen.View.RenderingStyleType.Shaded
partSaveStatus1 = dispPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
status2 = theSession.Parts.SetDisplay(part2, True, False, partLoadStatus2)
partLoadStatus2.Dispose()
next
Dim partLoadStatus6 As PartLoadStatus
Dim status6 As PartCollection.SdpsStatus
Dim partSaveStatus2 As PartSaveStatus
status6 = theSession.Parts.SetDisplay(part2, True, False, partLoadStatus6)
Dim nullAssemblies_Component As Assemblies.Component = Nothing
dispPart.Preferences.Modeling.CutViewUpdateDelayed = True
Dim partLoadStatus7 As PartLoadStatus
theSession.Parts.SetWorkComponent(nullAssemblies_Component, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus7)
partSaveStatus2 = dispPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
partLoadStatus7.Dispose()
else
'*** insert code to process piece part
lw.WriteLine("Part has no components")
end if
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
'lw.Close
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
(Thanks to Carlo Tony Daristotile)
http://www.nxjournaling.com/content/creating-subro...
JEHILL
