hydrostatic test
hydrostatic test
hydrostatic test
is entrapped air in the hydrostatic test cause of pressure drop?
RE: hydrostatic test
Yes.
how this occure?
are you have any refrence for your answer?
Basic Thermodynamics. PV=nRT.
If you have enclosed the vessel, then V, n, R are constant. Now, if you have a change in temperature, then the pressure will change almost linearly (on an absolute temperature scale).
Cheers,
Also high pressure air trends to dissolve into the liquid. It only takes a small amount to make a big difference in the liquid pressure
