NX Extract Geometry Modification
thread561-362063: copying bodies
Hello everyone,
I have a complex STEP file which shall be converted to a "living geometry" using NX. The NX Exctract Geometry Feature makes a great job, but the problem remains with the surfaces which cannot be modified. Is there any way/work steps for converting imported surfaces to a geometry which can be afterwards modified, based of course on the imported ones.
After converting the surfaces to NX from the STEP file how I can delete/remove/Isolate the reference which was created between the original/imported STEP file and the extracted ones.
Thank you.
Hello everyone,
Thank you.
RE: NX Extract Geometry Modification
www.nxjournaling.com
@Frank2288 yes, NX
Check out Menu -> Insert -> synchronous modeling. All of these commands can be used to modify imported geometry.
Other NX commands can also be used to modify existing faces on imported geometry, such as: offset, draft, X-form, etc.
I am curious: What would solidworks be able to do with the imported geometry that NX wouldn't ?
Have you seen what the X-form and the I-form can do ?
Tomas
