Using .AskChildrenOrder and Measure Bodies function
Cab somebody assist me in altering the code below: I have spent some time trying to produce something that will work, but I can't seem to figure out.
I got this code off of the GTAC support website. It uses the .AskChildrenOrder function to output the components in the assembly navigator order inside a list window in the same order as the Assembly Navigator.
I am aware that it doesn't perform the way it should all of the time, but in this case it performs the way I need it too. What I want to do is use Measure Bodies function to measure the volume of each component in the assembly in the order that .AskChildrenOrder function processes each part. Can somebody help me? Thank you!
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim theUFSession As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Public Sub Main(ByVal args As String())
Dim displayPart As Part = theSession.Parts.Display
Dim markId1 As NXOpen.Session.UndoMarkId = theSession.SetUndoMark( _
NXOpen.Session.MarkVisibility.Visible, "Reorder Components")
Dim theOrders As Assemblies.ComponentOrder() = Nothing
displayPart.ComponentAssembly.GetComponentOrders(theOrders)
Echo(displayPart.Leaf & " has " & theOrders.Length & " ComponentOrder objects")
For Each anOrder As Assemblies.ComponentOrder In theOrders
anOrder.Activate()
theSession.UpdateManager.DoUpdate(markId1)
Echo(anOrder.Name & ":")
WalkAssembyTree(displayPart.ComponentAssembly.RootComponent, anOrder, "")
theUFSession.Ui.DisplayMessage(anOrder.Name, 1)
theSession.UndoToMark(markId1, "")
Next
theSession.DeleteUndoMarksUpToMark(markId1, "", False)
End Sub
Sub WalkAssembyTree(ByVal theComponent As NXOpen.Assemblies.Component,
ByVal theOrder As NXOpen.Assemblies.ComponentOrder,
ByVal indent As String)
Dim kids As Assemblies.Component() = theComponent.GetChildren()
If kids.Length = 0 Then Return ' Not an assembly or sub-assembly
indent = indent + " "
' This does not always work - see PR 7421390
' Testing in the Toycar assembly only Chronological returns any Children
kids = theOrder.AskChildrenOrder(theComponent)
For ii As Integer = 0 To kids.Length - 1
Echo(indent & kids(ii).DisplayName)
WalkAssembyTree(kids(ii), theOrder, indent)
Next
End Sub
Sub Echo(ByVal output As String)
theSession.ListingWindow.Open()
theSession.ListingWindow.WriteLine(output)
theSession.LogFile.WriteLine(output)
End Sub
Public Function GetUnloadOption(ByVal arg As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
anOrder.Activate()
Next
End Sub
Next
End Sub
End Sub
End Function
End Module
