Pipe Deflection using CAESAR
Hi everyone, i know that if i want to have the deflection number, i must use a node at interest point, but when i'm checking a model a maximum deflection is one of my goal, so is there a way in CAESAR to set a max deflection or max bending stress in order to get a warning?. What if i want to set max bending stress, let's say, 30% of allowable stress and get CAESAR to check this, is that possible?. Or i must check span by other means.
How do you all deal with max pipe deflection using CAESAR?
Another question if you allow me, where do i set CAESAR to use hot elastic modulus for calculations.
RE: Pipe Deflection using CAESAR
Do not expect everything from the software.
I have found the best way to check deflections is to export the Deflection data after analysis to a spreadsheet. Then I can run a Max and Min function in Excel to find the worst cases. I also use filters to identify which nodes are worst. It is pretty much a manual procedure.
You might be able to do something similar for Bending Stress, but I am not sure where you would get the data.
I am surprised by the 15 mm max deflection criteria. I was taught stress analysis with a 0.1 inch (2.54 mm) deflection criteria or occasionally 1/8" (3 mm) criteria. If you don't mind, what industry are you using the 15 mm criteria in?
Duncan
This is the reason you need to be experienced on the modeling before involving with pipe stress analysis and at least you have the code with you to consult and get answers that you will have in mind if something goes different than you expected.
