Best "lifting" device for large (300 lb) Video Display Wall
Greetings-
New to the forums and not certain I'm posting in the right location but thought I'd give it a shot.
Working on a design requiring the ability to raise/lower a sizable Video Display Wall from a rolling (tubular steel) base frame. Consider this similar to a TV lift except considerably larger (110" diagonally) weighing approx. 300 lbs.)
Having limited time to explore my options, leaning towards linear actuators as a solution. Any advice to lend in finding a good company to turn to for both materials and advice? Is there a better choice for lift mechanisms than linear actuators?
Any input and suggestions would be greatly appreciated.
Thanks and looking forward to your feedback.
RE: Best "lifting" device for large (300 lb) Video Display Wall
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Needs something a bit more elegant unfortunately. Compact, smooth & quiet operation is critical as is used in conference/board rooms, etc.
Thanks!
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Yeah, pretty vague I do admit. This one was thrown at me as one of those "we need it in a month at a trade show" type things so hammering away. Just limited experience in linear motion so was hoping for feedback from some "been-there-done-that" (or something even remotely resembling) types.
Thanks for your answer. I do appreciate all the feedback I can get.
Alternately, you might be better off with a scissor lift and a small drive motor.
TTFN
Ted
