LCV 3015 Bll - Assist Gas Problem
Hi Guys,
We have been using our Amada LCV 3015 BII really successfully getting nice cuts until about four weeks ago. One of the operators reckoned that after changing the Oxy assist gas suddenly the cut quality deteriorated badly. We went through all the motions changing out bottles, checking lines etc but couldn't seem to find any major issue.
Since then have had two different techs in, now have replaced internal optics and aligned mirrors but we are still getting same issue. While trying to tune up machine following optic replacement we now cant get even the nitrogen assist gas to run at correct pressure (it just won't get there). We are thinking blockage or leaking of assist gas lines/ valves..... any ideas? Has anyone experienced this type of issue before? The cut looks ok on carbon steel but is really raggy on the bottom and the plume is all over the place.
Really appreciate any help here - turning into a very expensive exercise.
RE: LCV 3015 Bll - Assist Gas Problem
Check the proportional valve current or voltage (can't remember what drives it), if the voltage or current is fluctuating while it's cutting that might help a lot in the diagnosis.
Check the pressure sensor on the head, might be a problem there?
Machine suddenly lost all cut quality, we had to change cut settings significantly to keep cutting - couldn't do any of the thicker material though as not enough power.
Diagnosis was internal optics... we ordered the optics and struggled along while waiting for them
After a week of waiting the machine suddenly starting alarming out
Diagnosis was one of the blower fans had collapsed bearings
We decided to wait until optics arrive and replace the blower fan at same time
Replaced the optics and the blower fan, fired the machine back up and still got really poor cuts.
Diagnosis was issues with assist gas
We cleaned all the gas lines and the valves (all were full of gunk)
We pulled the head apart and replaced all of the O'rings
Replaced a couple of diaphragms on the adjustment valves.
Fired up machine again - best cuts ever, all problems appear to be solved
Cheers
Keith Cress
