NX assembly loading in native
When assembly is opened after editing part numbers, getting error "failed to find using current search option, part left unloaded". again I have to replace the part with edited part number part. This is takes lot of time as number of components in assembly is high. Where as in NX integrated with TCE don't have this issue assembly will load even after editing part number. Any suggestion same for native assembly also??
RE: NX assembly loading in native
While your Assembly is open, you should use 'Save As' to change the names of any of the Components of the Assembly as that will update the Assembly as well, but only if you also 'Save' the Assembly after saving your Components.
Or you could edit the names of the Components, open the Assembly and do a 'Replace Component' using the newly renamed Components to replace the older-named Components. Of course, you'll still need to 'Save' the Assembly after completing the 'replacements'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
