hi i need some info
hi i need some info
hi i need some info
Hello
      Its Adeel iam from dubai and im studing in O levels its going to be over after may-june so do me reply and tell me what i can do for my aeronautic engneering.
         i shall be thankful to you
RE: hi i need some info
Build yourself a model aircraft from scratch!
guess at a wing shape and then go from there! there is a book for model makers that has different wing shapes and corresponding data.
You will learn a lot and even if it doesnt fly i am sure you will get a good mark!
Good luck with your studies
