Info on two motors at my plant
Hello, my name is Logan. I work in the health and safety department of a company that produces generators for the R.V industry. I have been working with our maintenance guy to track down the service manuals for our machines so we could set up a preventative maintenance program. Everything has been running smooth up until I got to these two electric motors powering a couple of saws in our pipe area. I've scoured the internet, emailed the manufacturers, etc. but I still cant seem to find what I need. I need to know grease points, type of grease, oil, those kinds of things. I also don't really understand the nomenclature and specs that the nameplates and websites use, so that is hindering. To basically sum this all up, is there any advice/tips/info that I could get to make finding these things easier? There is an emod motor and a Saccardo Italia motor, that's all I really understand. I've attached some photos of the motors for reference in this link.
RE: Info on two motors at my plant
http://www.emod-motoren.de/show.php?ID=4358
(Source Website: http://www.emod-motoren.de/betriebsanleitungen_436...)
As for the other one it appears you will have to take a deep breath and make a few phone calls, if you have not already.
If you cannot obtain technical assistance for the Italiano motor you may be able to use the emod manual as a guideline if the RPMS, frame size, application, utilization, and purpose are the same or similar.
As far as the Saccardo, my main concern is that I cannot match up ours with their catalog. I'll keep searching, maybe get a hold of some dealers or something.
Your company produces generators? Hmmm... Locate someone with an electrical background within the company, they should know what to do.
Chuck
