NX9 - Journal Code Help Needed.... again. :o)
When in drafting, there seems to be some who like to see the borders around the views and some who don't. I thought it would be a good idea if I created a button to toggle the view borders on and off. I can record a journal to turn it on and one to turn it off, but I was wondering if someone could show me the way to use the "IF" correctly so one journal will turn it on or off depending on what the setting already is?
Just to make it clear, the same file will often be worked on by different people. That is why this is any kind of problem. Also, I find myself now working on something that I am constantly going back and forth turning the borders on and off.
RE: NX9 - Journal Code Help Needed.... again. :o)
No "If" is necessary.
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "toggle drafting view borders"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Dim preferencesBuilder1 As Drafting.PreferencesBuilder
        preferencesBuilder1 = workPart.SettingsManager.CreatePreferencesBuilder()
        preferencesBuilder1.ViewWorkflow.DisplayBorders = Not preferencesBuilder1.ViewWorkflow.DisplayBorders
        Dim nXObject1 As NXObject
        nXObject1 = preferencesBuilder1.Commit()
        preferencesBuilder1.Destroy()
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
Thanks cowski
This is awesome. I didn't know there was a toggle in code. Im gonna have to study this some to see how I get it to work for other things. lol
The code above works because the .DisplayBorders value is a boolean (true/false). The Not operation simply flips the value.
