Displacement Sensor
Displacement Sensor
Displacement Sensor
Hi everyone,
I'm looking for a sensor to obtain small motions. These sensors will be installed on columns, for hence, any sensor which needs a reference state is off the table. The main idea is to catch the displacements generated by a rotatory equipment which is supported by these columns. I'm thinking in something like a seismograph.
Any ideas?
Thanks in advance!
RE: Displacement Sensor
Hopefully micrometers for magnitude and accuracy on the same value order. Top price range usd$500-800.
I understand that inductive sensors have a lack of accuracy. Is there any kind of seismograph sensor?
If by posting here a sensor model is break the forum rule, please send me a PM. I will appreciate.
Thanks for your reply!
This sounds like something that is normally done with strain gages.
But I'm looking for displacements, the strain gage will give me strains only, right?. I though in using an accelerometer, since they do not need a reference frame. This for example http://www.geogage.com/product/vw_displacement_sen... will need a reference frame. The vecinity of columns/equipment is also vibrating, for hence this kind of solution (geogage sensor) will not be suitable.
IRstuff, we will need to make a hole in the baseplate to install that sensor? I think I'd not be allowed to do that.
Thanks to both for your help
Forgot to tell that, the trouble with the accelerometer is that I was not able to integrate the values in order to obtain velocity and displacement. Not to mention that the vertical motion has being influenced by gravity and we must apply filters. We obtained very strange results for sure.
"we will need to make a hole in the baseplate to install that sensor"
No, you can put the target, if needed, on the column. If you look at page 9, the sensors can be purchased for ferromagnetic targets, so if it's a bare steel column, that's all you need. Otherwise, you would glue a small piece of iron on the column and put the sensor on some sort of holder, like a tripod with an arm
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Are you looking for something off-the-shelf to do a job or to make something?
Keith Cress
We only need to get the small displacements of columns generated by an equipment which is supported by them.
It is possible to get displacements from a vibration sensor ?
Thanks !
