One size fits all Automatic Transmission fluid
Just wondering why a reputable transmission shop would use non manufacture approved fluid, just because the container says
it meets the spec? And we all know that the Fluid manufacture will not cover any damage to the transmission, nor will the shop after a month or so.
RE: One size fits all Automatic Transmission fluid
Lots and lots of transmissions have specific fluid requirements nowadays, and if the wrong one is used, it WILL be expensive.
je suis charlie
it meets the spec".
je suis charlie
Are not fluids designed for the specific manufacture? The fluid is as important as the parameters, the friction material, it is almost an integral part of the transmission. And yes the shop sticks their neck out doing that, but if it lasts 2 years or more and nothing happens short term, there is no recourse, everyone is off the hook. And any failures can be put on the normal use.
Labels are labels, how can they say it meets the requirements for a huge array of manufactures vehicles/ transmissions?
All the manufactures are not using the same transmission nor do all those transmissions have the same parameters, torque loading, materials etc.
By parameters I mean, the application of apply pressures, holding pressures, any modulation during shifting, clutch pack surface areas, friction material slippage etc. Sorry I just see too many variables for a one size fits all fluid.
Its not like motor oil, its plays an integral role in the operation of the transmission.
Money. That is the only reason.
je suis charlie
I went 'round on this for our VW Beetle. (01M transmission)
I really didn't want to pay the dealer's extortial price for official fluid.
It was - I forget - maybe the best price I could find was $13/liter or so?
It turned out that Valvoline has a fluid that they recommended for that service.
I used it, worked fine.
Valvoline wasn't willing to spend the $$$ to get it officially approved by VW.
So - was it a suitable application? VW might say "no"-
It's pretty obvious what I think.
Jay Maechtlen
http://www.laserpubs.com/techcomm
But substituting a carefully-researched alternate fluid is very different from grabbing generic Dexron ATF and throwing that in everything. Dexron + VW 01M = bye-bye transmission.
As others commented in the thread, there are also cases where the manufacturer does have a specific fluid listed. In that case, the specific fluid is listed in the vehicle specification.
Then, there are other licensed specifications. The GM DEXOS oil is an example. There is a specification for DEXOS oil which must be met. On top of that, the manufacturer also has to pay GM a fee to use the DEXOS symbol on their oil containers. So technically, you could use the DEXOS oil specification to find another oil that meets the specification even though it doesn't display the DEXOS symbol on the container.
So, if it meets the manufacturers specification then what is the problem?
I still don't understand the problem with a fluid that meets the vehicle specification?
OTOH there are lubricants in the marketplace that significantly outperform the OEM product (not likely in this case though).
je suis charlie
Required trans fluid: "MOPAR ATF+4 Automatic Transmission Fluid or equivalent licensed
ATF+4 product"
Service parts: "REPLACEMENT PARTS - Use of genuine MOPAR parts for normal/scheduled maintenance and repairs is highly recommended to ensure the designed performance. Damage or failures caused by the use of non-MOPAR parts for maintenance and repairs will not be covered by the manufacturer’s warranty."
Trans fluid selection: "Selection Of Lubricant - It is important that the proper lubricant is used in the transmission to assure optimum transmission performance. Use only the manufacturer’s recommended transmission fluid."
As you can see this owners manual makes it very clear that use of non-approved parts/materials will void the factory warranty. The trans fluid must be a factory product or a product licensed by the factory, and not simply a trans fluid the manufacturer claims to meet factory requirements.
je suis charlie
The warranty agreement you sign when you purchase a new car is a legal contract between you and the factory. The factory is obligated to bear the significant financial cost of replacing a transmission or engine that fails under warranty, but the owner is also obligated to fully comply with all of the terms contained in the warranty agreement they signed when they purchased the vehicle. It's a free market, and no one is forced to sign a new car warranty agreement. If you don't like the terms of the warranty agreement, then don't buy the car.
You can purchase a quart of genuine MOPAR ATF+4 tranny fluid for less than $15, and the total amount of fluid required at a 50K mile service would cost less than $100. I don't consider this one time cost to be unacceptable in order to ensure I will not have to pay for a transmission replacement during the first 100K miles of driving.
In the US, I`m fairly certain that Chrysler can`t force you to use their MOPAR brand ATF+4 unless they give it to you. The same applies to any other part you may replace.
Now, say you installed an aftermarket torque converter and the converter fails and dumps metal shavings into the transmission. Chrysler could deny warranty on the transmission. That`s be a case where the non-MOPAR parts clause could be applied.
I don't know about "the land of the free" but here in Australia, consumers have a range of statutory rights that cannot be "signed away" in a warranty document. For example, I am sure the makers would like to void the warranty if you have the car serviced at a non-dealer workshop but the reality is they can't do that.
je suis charlie
That's not quite right. MOPAR ATF+4 Automatic Transmission Fluid is likely a proprietary product. And in order to manufacture and sell this proprietary product in certain markets you would need a license or permission from MOPAR. In this example the owners manual states you must use the specific trans fluid noted to comply with the factory warranty terms. There is no mention of any specification.
On the other hand, here's what the owners manual states regarding engine oil: "Use API Certified SAE 5W-20 Engine Oil, meeting the requirements of Chrysler Material Standard MS-6395. Refer to your engine oil filler cap for correct SAE grade." As you can see, it allows use of any commercial engine oil product as long as it meets the API certification and Chrysler material standard requirements.
Here's what Chevron states about their ATF+4 product:
"Chevron ATF+4 Automatic Transmission Fluid has been registered with the Chrysler Corporation, license number 40630035."
"CUSTOMER BENEFITS - Chevron ATF+4® Automatic Transmission Fluid delivers value through: Warranty coverage as an officially approved Chrysler Group fluid"
je suis charlie
Besides, it's not like legitimate ATF+4 trans fluid is hard to find. Here is a fairly current list of licensed ATF+4 trans fluid brands:
Advance Auto Parts ATF+4®
Amalie ATF+4®
Auto Extra ATF+4®
AutoZone ATF+4®
Carquest ATF+4®
Castrol ATF+4®
Castrol Transmax ATF+4®
Chevron ATF+4®
Citgo Transgard ATF+4®
Coastal ATF+4®
Craft+4 ATF+4®
Federated Auto Parts ATF+4®
Great Wall ATF+4®
Havoline ATF+4®
MAG 1 ATF+4®
Mobil ATF+4®
Mobil Super ATF+4®
Mopar ATF+4®
NAPA ATF+4®
Northland ATF+4®
O’Reilly ATF+4®
Parts Master ATF+4®
Parts Plus ATF+4®
Pennzoil ATF+4®
Petro-Canada ATF+4®
Proline ATF+4®
Pronto ATF+4®
Pure Guard ATF+4®
Quaker State ATF+4®
Rallye ATF+4®
Ravenol ATF+4®
Sinopec ATF+4®
Super Tech ATF+4®
Tutela Transmission Force4 ATF+4®
Valvoline ATF+4®
Value Tech ATF+4®
Wolf's Head ATF+4®
Xcel ATF+4®
""Manufacturers can make ATF+4 fluids, but to use the trademarked ATF+4 name in their compatibility list, they must have their fluids tested and licensed by Chrysler engineers, and must use Lubrizol in their formulations."
really? they seem to think I can't mention the term?
Amazing.
Jay Maechtlen
One has to admit that this was a clever business tactic on the part of Chrysler. First they trademark "ATF+4". Then they create warranty requirements to use a trans fluid labeled as meeting "ATF+4" standards. Then they establish requirements for use of the trademark in the marketplace. So even if a fluid meets "ATF+4" performance standards, the producer cannot claim it publicly without permission from Chrysler. And any trans fluid that is not labeled as meeting "ATF+4" standards does not fulfill Chrysler's warranty requirements.
As GruntGuru alluded to, how would Chrysler know it's not a licensed product if the formulation is correct? At most they'll use some simpler test of the fluid to determine if it's correct.
Here is the outfit that handles licensing of the ATF+4 product for Chrysler: http://www.centerforqa.com/chrysler-licensing/
Going back to the OP, check out what the CFQA has to say in their Q&A section regarding a service shop using a fluid that is not ATF+4 licensed:
"My mechanic didn’t use ATF+4® when changing my transmission fluid. What should I do? - To ensure you have removed most or all of the existing ATF, it is recommended that you perform a total of three (3) changes using ATF+4®. It is further recommended that you do not mix ATF+4® with another automatic transmission fluid (ATF)."
Seriously? They recommend purging the transmission three times using fairly expensive ATF+4 fluid?
je suis charlie
