How to create a drilling model by an UDF
Hello
At moment to make a drilling by an UDF, i use a model NX5, because with NX7.5 (to NX10), i can't find the positioning menu.
I think that i have not the best method to create a reference model.
If somebody has a document or a video to make a UDF for a simple hole, i am interested ?
Thanks a lot for your help.
RE: How to create a drilling model by an UDF
Try using new hole feature is much better with respect to positioning and changing hole type than legacy simple hole.
Thanks, i am OK.
My problem is when i insert an udf in a part: I not be able to place correctly my model on a face ..... I think that my problem is when i define the udf references.
Is it possible to explain me step by step the building method to create a hole model ?
