Reuse Library search path, NX9
I'm successfully using a series of folders with commercial and custom parts in my Reuse system.
I use "From folder" for my assembly load options.
What I want to do is start building small assemblies into the reuse library.
Assemblies that are built with singular parts that are already organized in other reuse sub folders.
If I do this now... the assembly I drag into my work space cannot find those child parts because they are in other folders.
Isn't there a special search path exclusively for the reuse library that solves for this type of problem? Perhaps an environment variable or something?? Something I can use the \xxx\xxx... type of format to force sub folders into the path???
I prefer not to get into using "search folders" in load options because I'm in and out different projects all the time. It's such a hassel to constantly change those paths... even when they are saved off.
TIA for any help
TIA for any help
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
RE: Reuse Library search path, NX9
Dave
NX9, Win 7 Pro SP1
