Acoustic Simulation FEMAP
I would like to know how to define the CD=-1 in the GRID definition (nodes), by using FEMAP. It is necessary in order to carry out an Acoustic simulation of a Fluid Cavity.
Thank you very much in advance!
RE: Acoustic Simulation FEMAP
Use the Modify/Update Other/Node Type menu
After picking the nodes, you will see a menu to select the node type, choose fluid
Thank you very much! Do you mean the selection "type" for the nodes in the "node parameter" menu?
In my version this menu has these alternatives are only: O.Node , 1.Scalar Point, 2.Extra Point. No possibility for a -1.Fluid definition.
What version of Femap are you using?
Under node type you should see the following:
I'm using the version 10 in 32bit. It must be the problem :(
