Macros in solidworks
Hi Everyone,
This is my first questions to all of you.
I am working in solidworks 2003 & I have following
questions for my customization
1) Is there any way I can convert Coordinates of a point or 3d sketch directly from solidworks to Excel,Word. If Yes then how?
2)Is there any way I can customize my BOM in drawing if it is inserted from separate excel sheet?
3)We have PDM Works & Property Links at work. How I can fill up property links information in a way that It can be directly linked to my drawing files?
Before you proceed to my questions, please let me know first.
I am not a programmer. I haven`t used many macros either in solidworks or in excel. So please keep in mind and answer my issues.
Bimal Patel
Bimal Patel
RE: Macros in solidworks
1. Yes you can. Will the user select the point to be extracted or will all points on a selected sketch be extracted? Do you want the coordinates based on the sketch origin or the model origin?
2. Yes, you are able to attach to OLE items such as inserted worksheets. Modifying them, however, will require knowledge of the Excel API.
3. I do not use PDM Works and have not heard of Property Links. Are you looking to define custom properties in the drawing file so that they can be used by these applications?
These solutions will take some time to develop. You may want to consider posting them as separate threads.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
You can create a custome BOM in SW. Open the default BOM in Excel and save as "Custom.xls" Change the column headers to what you want to see on the drawing sheet and name the ranges accordingly.
You can create custom properties in your template parts based on what you need to see in the BOM. I have a unique set for each customer - part, assembly, drawing, and BOM.
This is not anything special, as I think everyone of us does this. It is not hard to figure out, since the whole process is detailed in the help files. Just search for "BOM"
Crashj 'bless us everyone' Johnson
When making a Custom BOM don't delete the header columns only hide them. If you delete them you will see some serious Remaking of the BOM time and time again after rebuilding it. So just hide the default columns if you don't need them.
IHTH,
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt always check the help*
> questions:
> I want to extract coordinates of points from model
origins.
> My utility is
> to generate a Roadmap (Checking Points for CMM) to check
> checking fixture of sheet metal part in a car position. Also I don't
know
> any thing about any API macro or excel Macro. If you can share the
info.step
> by step from beginning on these topics I will appreciate your help.
> Waiting for your prompt favourable reply.
> Thanks
> Bimal Patel
