UPDATE VIEWS DO NOT RETAINED AFTER PART CLOSE AND REOPEN
Hi
I hav a part that after I perform "update views" is OK, and after part save and open
I get "out of date".
Is theire a NX tool or a way to know and locate the cause of this.
Drawing is in non-master part (NX8.5)
NOTE: I can not post the part (company constraint)
Thanks in advanced
RE: UPDATE VIEWS DO NOT RETAINED AFTER PART CLOSE AND REOPEN
Do you save the part before closing it ?
Hi
Yes! I save before I close.
NX give no hint and no error massage.
Theire are many components and "try and fail" may take Time and irritation.
this is may be because of assembly load options settings. change the settings to AS SAVED then open the drawing.
Translate
אנגלית
עברית
איטלקית
אתר שפה
עברית
אנגלית
ערבית
ניסיתי וזה AS SAVEDלא עזר
Hi
I tried AS SAVED and that did not help.
We work with TeamCenter 8 if that can say something.
I was expecting from NX to give me a hint ( Which object is causing problems )
Hi
Does it appear that only one view is out of date?
Possibly a section view?
What tasks do APDATE VIEWS do ?.
What objects it touches ?.
Yes 1 view of 7 keep its apdating and the other not.
Now the part does not bother me and I decided to leave it as is.
But my curiosity how to put my finger on the wayward object not let me
