what is the file type to define a profile by points?
Hi All
How do we define the profile of a cam for example , that might be a bspline , by importing points ? and what is the type of the file that ADAMS can read from ? In ADAMS 2014, I dont see this command , and how should I order the points in that file ?
RE: what is the file type to define a profile by points?
I suggest you look in the help files, or even the tutorials. I suspect that ADAMS will need the points in order of increasing X (the first column). Frankly this forum isn't really aimed at getting complete noobs off the ground, so don't be surprised if some of your questions go unanswered. MSC offers a variety of support options.
Cheers
Greg Locock
@Greg
I suggest you look in the help files, or even the tutorials : I didn't find , if you know where it is , kindly mention it here, it's a forrum for everyone, noobs and professional
Frankly this forum isn't really aimed at getting complete noobs off the ground : I read the policies of the forrum , none of the lines refered to such a thing
