How to Use Block styler (.dlx) with Knowledge Fusion classes (.dfa)
NX UI stylers (.dlg legacy) are convenient to make and goes hand in hand with Knowledge Fusion classes(.dfa), I mean to say it gets instantly linked with UI via matching attribute names(.dfa->.dlg).
Currently, I am usning NX9 and observe that now a day’s the “UI styler” are getting replaced by “Block stylers” (.dlx) for betterment in NX-Open, can anyone help me out to know whether, I can use “Block Styler” with KF Class similar to UI? (.dfa->.dlx)
If the answer is yes, it will be grateful if you can put any clue to get binding string.
Thanks in Advance!
Thanks in Advance!
RE: How to Use Block styler (.dlx) with Knowledge Fusion classes (.dfa)
You define a KF class that extends the %ui_comp class. Your class can then define dialog blocks using instances of %ui_comp_??? classes.
Its hard to describe the entire details of how to do it here, but I'll attach an example class file of mine and maybe you can work it out from there.
Note that the example class file references bitmaps etc for some of the blocks, but I have not included those, so the class will not work as-is.
Graham Inchley, Systems Developer, Sandvik Coromant. www.sandvik.com
HP EliteBook 8760w, Win7, 16GB. Developing in: Java | C | C# | KF
Production: NX8.5.3.3 MP4 64bit
Testing: NX9.0.2.5
Your post is helpful to understand the working of BlockStyler with KF!
At the same time, I am bit surprise to see that it is not working as UI-Styler use to.
Thanks for your prompt support.
Amit
