NX9 - Export Entire Assembly to a single PDF?
Someone needs to export his entire assembly to a PDF file, but they want it all to end up on one PDF file. We can do these one at a time and append them but that will take forever. Is there a way to batch PDF an assembly to one PDF file?
As stated in the title, this is NX9.
Our model and drafting is in the same files, if that makes a difference.
This is an assembly with the details as separate part files and brought in as components.
Thankyou for any help anyone can offer.
RE: NX9 - Export Entire Assembly to a single PDF?
With some programming/scripting you could possibly cycle through al of the component files in the drafting application and print the PDFs, but the would be individual files. These could then be combined by the script.
Ben Loosli
As for the rest of what you said, it made little sense to me. Sorry.
This looks like it does the PDF for the assembly drawings. However, on this occasion, our customer wants everything on one PDF. Including the details drafting sheets. So if an assembly has 6 make details in it, we will needs the assembly drafting sheets, the BOMs, and the drafting sheets for all 6 details to show up in one PDF.
You can always use journal to do the job for You.
Here is my personalized journal to export PDF. It create folder "PDF" in place where part file is.
CODE
Option Strict Off Imports System Imports System.IO Imports System.Collections Imports System.Windows.Forms Imports System.Windows.Forms.MessageBox Imports NXOpen Imports NXOpen.UF Module NXJournal Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display '********************************************************** Sub Main Dim dwgs As Drawings.DrawingSheetCollection dwgs = workPart.DrawingSheets Dim sheet As Drawings.DrawingSheet Dim i As Integer Dim pdfFile As String Dim currentPath As String Dim currentFile As String Dim exportFile As String Dim partUnits As Integer Dim strOutputFolder As String Dim strRevision As String Dim rspFileExists Dim rspAdvancePrint 'determine if we are running under TC or native Dim IsTcEng As Boolean = False Dim UFSes As UFSession = UFSession.GetUFSession() UFSes.UF.IsUgmanagerActive(IsTcEng) partUnits = displayPart.PartUnits '0 = inch '1 = metric If IsTcEng Then currentFile = workPart.GetStringAttribute("DB_PART_NO") strRevision = workPart.GetStringAttribute("DB_PART_REV") Else 'running in native mode 'currentFile = GetFilePath() & GetFileName() & ".prt" currentPath = GetFilePath() currentFile = GetFileName() Try strRevision = workPart.GetStringAttribute("REVISION") strRevision = Trim(strRevision) Catch ex As Exception strRevision = "" End Try End If exportFile = currentFile 'strOutputFolder = OutputPath() strOutputFolder = CurrentPath + "PDF" 'if we don't have a valid directory (ie the user pressed 'cancel') exit the journal If (Not System.IO.Directory.Exists(strOutputFolder)) Then System.IO.Directory.CreateDirectory(strOutputFolder) End If strOutputFolder = strOutputFolder & "\" 'rspAdvancePrint = MessageBox.Show("Add advance print watermark?", "Add Watermark?", MessageBoxButtons.YesNo, MessageBoxIcon.Question) Dim shts As New ArrayList() For Each sheet in dwgs shts.Add(sheet.Name) Next shts.Sort() i = 0 Dim sht As String For Each sht in shts For Each sheet in dwgs If sheet.name = sht Then i = i + 1 If rspAdvancePrint = vbyes Then pdfFile = strOutputFolder & exportFile & "_advance" & ".pdf" Else If strRevision <> "" Then pdfFile = strOutputFolder & exportFile & "_" & strRevision & ".pdf" Else pdfFile = strOutputFolder & exportFile & ".pdf" End If End If 'the pdf export uses 'append file', if we are on sheet 1 make sure the user wants to overwrite 'if the drawing is multisheet, don't ask on subsequent sheets If i = 1 Then If File.Exists(pdfFile) Then rspFileExists = msgbox("The file: '" & pdfFile & "' already exists; overwrite?", vbyesno + vbquestion) If rspFileExists = vbYes Then Try File.Delete(pdfFile) Catch ex As Exception msgbox(ex.message & vbcrlf & "Journal exiting", vbcritical + vbokonly, "Error") Exit Sub End Try Else 'msgbox("journal exiting", vbokonly) Exit Sub End If End If End If 'update any views that are out of date theSession.Parts.Work.DraftingViews.UpdateViews(Drawings.DraftingViewCollection.ViewUpdateOption.OutOfDate, sheet) Try ExportPDF(sheet, pdfFile, partUnits, rspAdvancePrint) Catch ex As exception msgbox("Error occurred in PDF export" & vbcrlf & ex.message & vbcrlf & "journal exiting", vbcritical + vbokonly, "Error") Exit Sub End Try Exit For End If Next Next If i = 0 Then MessageBox.Show("This part has no drawing sheets to export", "PDF export failure", MessageBoxButtons.ok, MessageBoxIcon.Warning) Else MessageBox.Show("Exported: " & i & " sheet(s) to pdf file" & vbcrlf & pdfFile, "PDF export success", MessageBoxButtons.ok, MessageBoxIcon.Information) End If End Sub '********************************************************** Function GetFileName() Dim strPath As String Dim strPart As String Dim pos As Integer 'get the full file path strPath = displayPart.fullpath 'get the part file name pos = InStrRev(strPath, "\") strPart = Mid(strPath, pos + 1) strPath = Left(strPath, pos) 'strip off the ".prt" extension strPart = Left(strPart, Len(strPart) - 4) GetFileName = strPart End Function '********************************************************** Function GetFilePath() Dim strPath As String Dim strPart As String Dim pos As Integer 'get the full file path strPath = displayPart.fullpath 'get the part file name pos = InStrRev(strPath, "\") strPart = Mid(strPath, pos + 1) strPath = Left(strPath, pos) 'strip off the ".prt" extension strPart = Left(strPart, Len(strPart) - 4) GetFilePath = strPath End Function '********************************************************** Sub ExportPDF(dwg As Drawings.DrawingSheet, outputFile As String, units As Integer, advancePrint As Integer) Dim printPDFBuilder1 As PrintPDFBuilder printPDFBuilder1 = workPart.PlotManager.CreatePrintPdfbuilder() printPDFBuilder1.Scale = 1.0 printPDFBuilder1.Action = PrintPDFBuilder.ActionOption.Native printPDFBuilder1.Colors = PrintPDFBuilder.Color.BlackOnWhite printPDFBuilder1.Size = PrintPDFBuilder.SizeOption.ScaleFactor If units = 0 Then printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.English Else printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.Metric End If printPDFBuilder1.XDimension = dwg.height printPDFBuilder1.YDimension = dwg.length printPDFBuilder1.OutputText = PrintPDFBuilder.OutputTextOption.Polylines printPDFBuilder1.RasterImages = True printPDFBuilder1.ImageResolution = PrintPDFBuilder.ImageResolutionOption.Medium printPDFBuilder1.Append = True If advancePrint = vbyes Then printPDFBuilder1.AddWatermark = True printPDFBuilder1.Watermark = "ADVANCE PRINT NOT TO BE USED FOR PRODUCTION " & Today Else printPDFBuilder1.AddWatermark = False printPDFBuilder1.Watermark = "" End If Dim sheets1(0) As NXObject Dim drawingSheet1 As Drawings.DrawingSheet = CType(dwg, Drawings.DrawingSheet) sheets1(0) = drawingSheet1 printPDFBuilder1.SourceBuilder.SetSheets(sheets1) printPDFBuilder1.Filename = outputFile Dim nXObject1 As NXObject nXObject1 = printPDFBuilder1.Commit() printPDFBuilder1.Destroy() End Sub '********************************************************** End ModuleWith best regards
Michael
monolithic pdf
www.nxjournaling.com
Ivan, .... If only this world was set up where my bosses would buy every program I wanted from them.
Cowski, I will look at the link.
Again, I do thank all of you for your time and help. :)
Your code did the job with one problem, and I am not sure how easy that would be to fix. I had the guy who needed it run this journal on a small assembly to test it and it worked, but the sheets were out of order. The assemblies drawing sheets were together but they were out of order, then the detail sheets were out of order as well.
However, I do want to be clear that this job has lost its importance at this time because the gentleman who needed this ran PDFs the normal way for the assembly, then did the details individually and appended them to the assembly PDF. I was trying to find a way to make the job easier but he went ahead and did it the hard way because it is not the usual job for us. So if you were to address the code putting the sheets out of order, it would be more for just fixing the problem than for what is needed at this time. I just wanted to let you know so you don't spend time on it thinking it was still needed.
But if you ever do get free time in the future and dig into it. I wouldn't mind having that in case anything else comes up in the future like this job. lol Just no hurry on it.
