SWEPT 'rotation'
SWEPT 'rotation'
How can I 'rotate' a swept during the operation ?
In attached picture I tried to explain what I would like to do/become.
I thought it should be possible to 'rotate' the swept over a certain angle ?
(The workaround is working with a law controlled helix or contructed spline)
I once saw a YOUTUBE movie on this topic, but can't find it back ...
Thanks for your help !
regards
regards
Freelance 3D ENGINEER
www.f-dh.be
RE: SWEPT 'rotation'
www.nxjournaling.com
The twist should be around the main-part axis, and not along the guide itself (Or did I do something wrong)
How can I get the picture visible ?
www.f-dh.be
It depends on where you upload your file. If you use the attachment link below the reply box, that location always seems to work for me (it may be different for others).
www.f-dh.be
I think your best bet would be to create the guide that gives you the result you want. Here are a few methods that I would try:
I'll spent some more time on youtube to find the video
thanks anyway !
www.f-dh.be
