Missing Blend Reference Edges
thread561-356772: Removing edge blends with lost references
Hi Cowski.
I tried the Missing Blend Reference Edges Journal in NX9 without any luck.
Does it need to be modified for NX9
Ian
NX9 - TcAE 10
Hi Cowski.
Ian
NX9 - TcAE 10
Automotive
EDAG Engineering Germany
NX9.0 TcAE 10
RE: Missing Blend Reference Edges
The journal only looks for blends with missing parent references; if the blend has warnings for any other reason, it won't change it.
I ran a quick test on an NX 9 file and the journal worked correctly. Some more detail on what the code does can be found here:
http://nxjournaling.com/content/blend-reference-cl...
www.nxjournaling.com
