Problem in importing of the results of a deformation from a forming software in * .igs * format
Hi All
I have problems in dealing with the parts that i have to import in Solidworks , that are meshed , and deformed , and also are imported into solidworks with a mesh , the result is a part with a lot of facets and small lines ,
and the problem will be that the surfaces are not straight and have angles , not possible to do anything with it , is there a suggestion or solution for this ?
RE: Problem in importing of the results of a deformation from a forming software in * .igs * format
On my blog there are 4 examples of ways to use data like this. They are mainly using Catia however these methodologies should be instructive.
I hope this helps.
Rob
Rob Stupplebeen
OptimalDevice.com/blog
Rob's LinkedIn
